Nazo
- Apr 2, 2002
My grandmother bought a lighted magnifier at a thrift store or something and it didn't come with its power supply. Luckily it had the info on the plug, 10V @ 50mA (well, it's a LED, but that is still pretty low, lol.) So I tried to order an adapter for it, but of course there aren't a lot of 10Vs out there. I wanted to keep things simple and cheap though and preferred not to try to have to make a 12V work or something. I thought I found a good one on Mouser -- a bit overkill (500mA) but sufficient fine really. Unfortunately, when it shipped in I discovered that apparently I ordered an AC adapter! I've already cut the end off to attach the somewhat unusual sized connector this thing uses to the end, so returning it isn't really an option.
Rather than make things complicated though, since this is a pretty low budget project, I decided just to convert AC to DC with diodes. Apparently this is called a "diode bridge" (which I'd had no idea about before, but managed to find out via searching for something completely unrelated.) I ran across this article on Wikipedia once I knew what to look for: http://en.wikipedia.org/wiki/Diode_bridge They mention using a capacitor in parallel to smooth the output. From what it sounds like they are saying though, I'd need one rated for the output voltage I want? Eg 10V? Or do I misunderstand? I've never really quite gotten the hang of capacitors I must admit. Someone else told me differently on the matter (would you believe someone at RadioShack who actually understood what a capacitor even IS? Lol, lately all they seem to be good at there is stuff like cellphones...)
I've managed to salvage a few things so hopefully I won't have to buy anything. In fact, right after I went to all the trouble to actually connect four diodes together, I found an actual diode bridge in an old broken PSU, so took that. In looking for a smaller capacitor, I did find a 16V, 100μF electrolytic capacitor. Would something like that work if it doesn't actually have to be 10V? Should it be more or less capacitance?
BTW, should I even bother to run a resistor across it to discharge it? It's pretty low voltage (even the 16V isn't much really) and I would be happier if power draw when it's not in use was kept at a minimum. Of course, the whole thing is pretty low power to begin with. However, I don't think it's likely to ever get discharged by touch or anything anyway.
