using 2 momentary buttons as a CMOS reset
jruley
I have an array of 3 buttons and I want to make it so that you have to press 2 of them at the same time to reset the CMOS. is this possible? I looked around on google but i couldn't find anything so I'm bringing it to you guys.
yup, it's actually quite easy. Assuming you have a two-pin header on the mobo, just run a wire from one pin to one button, out the other side of that button to the second button, and out the other side of the second button to the second pin on the mobo. (short version: wire the buttons in series)
