Username change?
Status
Not open for further replies.
Captain Kirk
Is it possible to get one's username changed on the [H]? I looked in the vBulletin FAQ and the sticky in this forum, but couldn't find an answer. I don't really use the username much anymore; I've sort of outgrown it ;).
Thanks in advance!
You must not have checked the FAQ in this forum for your answer. ;)
(7) How do I change my username?
Usernames are not changeable unless it is to the advantage of the Administration ie: politically incorrect/trollbait/disgusting/improper usernames that somehow slipped through the filter. If you want a different name, you must have an admin close your present account and then you may re-register with the new name.
Thanks in advance!
Even in spite of the FAQ, it's been done before IIRC. Good luck!
Captain Kirk is a pretty awesome name; I think you should stick with it ;).
Status
