Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm thinking of getting a 120mm heatercore (chevette) that has been used for a few months. I was wondering if there is a life span for heatercores (i.e. does it start to break down after so long, etc.)?
I fyou buy a used one, make sure you clean it out real good, if you search the forums, you will find threads with horror stories from people not cleaning them out properly
You should really just get a new Bonneville or Chevette heater core instead of getting one used, unless you're getting a good deal and are stupid like me http://www.hardforum.com/showthread.php?t=925813
Hey, it was $12 shipped, and now it isn't messy anymore so it wasn't too bad, just really nasty.
