ycchan said:I used rubbing alcohol but it wouldn't remove the rest of the paste. I'm afraid to push hard on it. I can make out the ATI sign but the letters underneath is all blurred due to the paste![]()
sparks said:isopropyl alcohol and rubbing alcohol are not the same thing.
Use isopropyl alcohol it will evaporate and not leave anything behind.
rubbing alcolol has mineral oil in it and will leave a film..BAD
sparks
OPUS1 said:use only isopropyl alcohol at least 91%
Get it at CVS or the like
all the other stuff will leave a residue at the microscopic level and degrade perfomance or break down the paste you put back on!!!!!
OPUS1 said:Acetone and Xylene have carriers that will stay behind!
As stated above the old demon alcohol (at least 91%) will evaporate
