Use 250GB drive with DOS/Win98
LstBrunnenG
Is it possible to use a 250GB drive with either of these operating systems? The motherboard definitely supports it, but I'm unsure if the OSes will.
I ask because I only have a 40 GB or a 250 GB IDE drive. The 40 means that Win98 will only get around 20 or 30 (with Lunix and DOS dividing the rest). I'd really like to give it more. Keeping the DOS and Win98 partitions within the 128 GB limit won't be a problem - Lunix can have everything above that - but it'd be nice if I could have a 2 GB FAT16 DOS partition and then a 126 GB Win98 FAT32 partition.
Grub would be the bootloader so no problems there, fdisk on Lunix would be used to do the partitioning, and mkfs.vfat would be used to do the formatting. I just need DOS and Win98 to install and run. As long as I keep the partitions in the first 128 GB, am I good?
First off, its Linux. You should be fine with the partition layout like that.
So for the record this did NOT work. MS-DOS was happy as a clam living out a sheltered life in the first 2 GB of that drive. But Win98 would not install.
Backing up a bit, here's the whole story for posterity. Installing DOS to my 80 GB SATA drive worked fine. I tried installing 98, which recognized the full partition and succeeded in copying files over, but after the reboot step it simply said:
DISK I/O ERROR
REPLACE THE DISK, AND THEN PRESS ANY KEY
I fiddled with everything I could think of in the BIOS to no avail. So I figured that, despite the way the BIOS was bending over backwards to give the illusion that the SATA drive was in fact an IDE drive, I'd try the 250 GB IDE drive. Again, DOS worked well, but when I tried to install 98 to a 100 GB partition well within the first 128 GB of the drive, I observed the same behavior.
Googling showed that earlier versions of 98 had a max partition size of 64 GB. So I tried shrinking the partition to 40 GB. Still did not work.
So I give up. DOS and 98 can share the 40 GB drive, and the 250 GB drive will go in as a secondary with WinXP, Lunix, and maybe a FAT32 shared data partition.
I haven't installed Win98 in a really long time, but I would have written 0's to the start and finish of the drive first. The MBR and boot sector are finicky animals, and depending what OS's have been installed on the drive Windows 98 may have problems doing what it wants to the drives.
Have you tried hiding the DOS and Win98 partitions from each other using Grub? DOS and DOS-based versions of Windows absolutely cannot stand booting from or residing on partitions other than C:, thanks to their stupid simple bootloader. By hiding the partitions from each other, DOS will think it's on C:, and Windows 98 will think its on C:.
It's a little kludgy but this setup has worked for me in the past.
I figured this out too. While I install 98, the DOS partition masquerades as a Linux partition.
I tried putting GRUB in the MBR. I don't think there's a big chance of there being anything leftover in the boot sector of the partition, especially since this happened on two separate drives with partitions in spots where there had never been partitions before.
Just wondering, but... can't you run win98 or DOS inside a virtualbox VM instead? Would be easier to install i'm sure. Windows 98 always uses 100% of your cpu time though, you may have to install an application known as "rain" (not sure how exactly it was called). This does what other OS do: send your CPU a noop-instruction for unused cpu cycles. Otherwise you continuously get 100% cpu usage, which is not very cool.
If you can show me a VM that can run 98 and has a Sound Blaster 16 emulator I would be grateful.
Otherwise I will content myself with real hardware, and this wonderful PCI card that can emulate the SB16.
Virtually all vm software today emulates at least a sb16. :confused:
I personally would go with VMWare Player (emulates an Ensoniq 1371 by default, but you can edit the vmx file to emulate a sb16 card instead) or even MS Virtual PC 2007 (best DOS support in my experience). Virtualbox has not and will not officially support any Windows 9x/Me OS, making it a pain to install and run, IMO.
If you're not running games in DOS or Windows 98 that require hardware 3d acceleration or 3DFX, then go the virtual route all the way.
