Went to the store and looked at the various wireless adapters they had. Was surprised to find a large amount of USB devices, some with, and some without antennas. They ranged from 15 to 55. The cheaper ones had no antenna.
The PCI cards had between 1 & 3 antennas, and cost around 30...
I assumed PCI would be better than USB, but held off on purchasing anything until seeking advice here. I'm looking for something that doesn't really need huge range, or to be cutting edge, although I'd like the best bang for the buck.
Any feedback would be appreciated, Thanks.
