USB turn on/off computer?
ipam45
today my computer is acting a little werid. when i turned it on it went to the profile thing instead of just loading to my desktop. after that i used my usb drive for a second...when i pulled out the usb it restarted my computer and again it took me to my profile page.
what the hell is going on.
Do a full cold shutdown
so...
Reset your CMOS, power up (with the default profile)... then shut down your computer from the start menu.
Restart and see if the USB issue still persists... try a different USB device too.
If you get a short in the USB plug, your computer will hardshutdown and might not re-start untill everything is reset.
If you connect the hot and cold wires on a USB plug, and plug it in to most (if not all) IBM laptops, it will lock up, and wont re-start until the battery is removed :p.
