USB Tuner/Printer Help
Temoryian
I'm trying to be even more of a slacker at work than I already am. I recently purchased a USB TV Tuner but it doesn't work without the software. No matter what I try I can't get the software to run only off my portable hard drive...it always ends up puting something on my home computer. Therefore I can't take the tuner to work because I need something that won't require me to put software on my work computer. Make sense? Anyone know of a good USB TV Tuner that will work without installing software onto a computer?
Also any suggestions on a new all in one printer for a family member? Preferably an HP product. It's just for home use..looking to be able to print/scan/fax/copy. Looking for the best bang for the buck.
Thanks for the help.
