USB To Mobo Extension/Longer Cable
P4rD0nM3
Hey guys, do you know where I can get a longer cable for the front panel for my USB/Flash Memory reader? It's so short that I can't route it behind my motherboard tray.
I have the Lian Li one. Please take a look at this picture (Taken from NewEgg.com).
I need the middle part.
Hmm weird I just noticed it only has 5 pins on that image while mine has 10, I suppose I'm going to get the 10 pin connector.
You could make your own, for much cheaper. Just extend the wiring. Though simple and clean the above is your best best, I guess.
Thanks for that suggestions but I'm not really good with electronics, hehehe.
Well the low tech way, is cut the wires, buy 26 or so gauge wires, and just connect the tips, either with solder, or electrical tape. I am not sure if theres impedance or other requirements, but that should work, as those adapter wires are essentially that, a longer wire. But if your not comfortable, then buy the above, looks pretty decent ;)
Best to use shielded cable, not just plain wire unless the run is very short.
You can buy longer cables for internal USB cables. However, they will not be any cheaper than the extension cable Arcygenical suggests.
Anyway, I have a slight problem right now...after the extension cable, the transfer rate from the flash card to the hdd is HELLA SLOW. If it's from the hdd to the flash card, it's just about right.
Here is what I did...
Then add
If you notice it has all the pins in the extension cable, but the one from Lian Li has like one blocked.
So what I did was just pluck out one pin from the extension cable and it fit...my question is, was that stupid?
LIKE...
No its not a problem at all to remove that one pin. its gone to help keep you from pluggin it in wrong. If yo can I would plug the hole on the other end as well, find some piece of plastic and stick it in the correct hole. the only thing you need to watch is make sure you get the right hole/pin.
So that means my cf just went fubar on me huh? Because it's like slow as hell now and I thought it was my camera formatting the cf or it was this mod that I did to extend the cable...
It's probably that mod.
I used those same cables to extend my USB port headers (move the connections behind the motherboard tray for cable management), and my front-panel USB ports are really flaky. Some devices don't work at all (one of my flash drives), some work but come and go (my Zen Stone Plus), some work fine (one of my other flash drives), and often I can't get both ports working at once.
I think it's because the extension is unshielded.
So I plan to take things apart and run the front-port cables directly to the motherboard, but I haven't gotten around to it yet. In the meantime, every now and then my Zen Stone's autorun dialog pops up because it went disconnected and reconnected again.
I bought a long USB cable and cut off the connectors. I also got some connectors that matched the MB headers (2x5 pin) then just connected up the wires to the connectors. Buying a long USB cable was easier than finding the same quality shielded cable without a long, involved mail-order or drive to another city.
In the case of the cable in the first photo, you'd only have to cut the connector from one end and add the new MB connector to the other end.
