Any recommendations on a good, but budget USB sound card? Do these things even work well?
for my desktop, which is using onboard sound atm. it doesn't have any pci express slots to spare.
I've noticed sometimes at higher volumes on my speakers, there's some distortion. i'm sure it's not the speakers because when i lower the master volume in windows but i up the speaker volume it sounds perfectly fine.
i'm not really too picky about going and finding high def versions of the music i listen to... but i'm sure i have some high bitrate songs.
as for what i'd use it for... it's for everything, music, movies, shows, gaming, etc
if it helps, i'm using logitech Z-2300s
i do have regular pci slots, is there a big difference in quality from usb to regular? i figure with a usb it would be convenient to use it with my laptop if i want to
