Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Once in a while if I plug a usb key into the ports on the case or even get close to the ports the system will reboot. Are the plugs on the usb ports on the case faulty?
