USB & PS2 Ports totally dead?
phobic
Ok this is driving me absolutely nuts. My USB ports don't work... at all. My system was working 100% perfectly earlier until EQ2 decided not to load. I usually fix this problem by rebooting my PC. I nstead of booting, I get a message saying my keyboard isn't detected. I'm using a Logitech wireless keyboard and the reciever shows no lights, as if there is no connection. Originally, I had everything plugged into a powered USB hub but even if I connect my devices directly into the PC, nothing happens.
After so many reboots, my PC will detect a keyboard and it works fine until I have to boot into XP. The Windows logo comes up, then the system just hangs. Also, my keyboard's reciever will disconnect (all the lights will shut off).
This is extremely bizarre. The keyboard does work in when connected to my laptop so that's probably not the problem. Any ideas before I end myself? Probably not that extreme but today really sucked.
System:
Shuttle SN25P
AMD A64 3700
2GB Corsair XMS
Asus X800XL
try a cd bootable linux distro (aurox, knoppix) and see if the keybord will work.. it might be that your XP install got screwed big time.. you could also try booting in safe mode..
I think you may be right with the XP install. Very odd a software problem can cause trouble before the software starts. At any rate I'm reinstalling XP with a bootable CD now so hopefully it works.
I might sound like a broken record on this, but those SFF's are pretty hot inside, have you had a good look at the mainboard caps? Reason I ask is I've seen recapping kits available for some of the older ones, the heat really saps the life out of the caps on the shuttle mainboards.
Slartibartfast said:
Are the ports enabled in the bios? ;)
You can disable USB, but I don't think you can disable PS/2. After all, you need at least a PS/2 port so that you can use your keyboard and get into the BIOS in the first place.
Turns out reinstalling Windows did the trick. Thanks for all the suggestions. :cool:
I thought I should ask this question bumping this thread since my problem is related. I just had my USB ports go off on me while playing UT, however they are not completly dead as the light does flicker from time to time. I tested with different mice and both ports, all suddenly stop responding / lose power / become undetected. For some reason, I can move my mouse in a certain position, and it will start working again all of a sudden. The mouse is then ok for a few minutes, until it stops working again. I haven't had this problem until today.
Would reinstalling XP work in this case too, or am I looking at more of a hardware problem?
