USB problems on Asus A8N32-SLI... please help
BellaCroix
I've been asking on the O/S forum but now I'm fairly certain this is a MoBo issue and not to be blamed on Borg Gates (this time).
I've been working on getting the new build to work for the last 12 hours and am close to pitching the whole thing out the window... first the build details:
Asus A8N32-SLI Deluxe (BIOS version 1205)
AMD 4000+ Athlon 64
XFX 7900 GT (Driver Version 91.31)
Dual 250 gig SATA2 HDDs (SATA2 Mode - No RAID)
Windows XP (Service Pack 2 with all "Critical" updates downloaded and installed)
No overclock, no disabled/modified services, no performance tweaks.
Problem I'm having: Frequent crashes of O/S in loading especially after connecting USB devices.
Specifics: After restarting PC after connecting or attempting to install USB devices Windows fails to load. Clear POST with no errors, instead of OS loading the system reboots itself. Monitor displays the "Off mode in 5 seconds" display, re-POSTs, then errors out that last attempt to load failed and what version of "safe mode" would I like to load. If I shut down, disconnect the USB devices and reattach PS/2 mouse and keyboard it is able to load Windows as normal.
BTW: if it matters, the mouse is a Microsoft Wireless IntelliMouse Explorer 2.0 and the keyboard is a Microsoft Office Keybaord.
I noticed theres a ton of options in BIOS for USB setting and was wondering if anyone had any suggestions of how those should be set, had heard of problems like this before, know that this ASUS board sucks with USB, etc?
Apparently, it's not only the USB:
I just installed the SBC-Yahoo DSL software and that casued the same problems as well.
In the process of installing the software I noticed everything happening in the process, maybe this can help find my config problems:
For a moment it displays that it's installing "Microsoft VM"
It then restarts the PC (That restart works correctly)
The software loads and appears to operate as normal
If I then restart the PC it fails to load, I enter safe-mode to revert to an earlier restore point and notice that in order to get a good load I have to go back over a restore point where something called "Visual IP Insight" was loaded (presumably as part of the restart while loading the software).
Any suggestions? I can't figure out if this is the MoBo or the O/S
