usb problemOs
antok86
all of a sudden front usb on qpack stop working and the two on the back left section but the other 2 in the back right work....seems kinda wierd....i duno wat happened. i didnt do anything new.
help
thanks
Make sure the headers on the mobo are plugged in or plugged in correctly. They may have come unplugged if you moved your computer. If all the ones in the back work fine, then the hub on your mobo should be fine and therefore, the plugs should be working..
only the 2 on the right work.....the 2 on the left dont. i pluged in my ipod mini and it charges on the 2 on the right, but nothing works on the 2 on the left. i restarted and everything just happened pretty random cuz i was using them yesterday morning, and i didnt move my computer
