monkoosbob0
- Jul 17, 2008
What I really want to make is a portable RAID. I need it for databases, so it just has to have fast access times (probably RAID 5), and it must be windows compatible.
I've seen people do this before, but not with Windows compatibility, and i'm not sure if theirs are PnP.
It would be really cool if i could just use the windows disk management util, but it only works on dynamic disks, which is (almost) impossible to get to work on a flash drive.
Does anyone have any suggestions? Any programs that you know of that might help?
My next step is to try out that Hitachi Microdrive driver that I've heard works for this, but I've also heard that it doesn't work in 64-bit vista, which is what my machine is running right now. So, it's not impossible, it just makes it very difficult to do. http://www.usbhacks.com/forums/viewtopic.php?p=5&sid=7dc9533127bc8c5d0e82383e39c2feca
Thank you in advance.
