Oct 14, 2004 #1 S Stefan Limp Gawd Joined Apr 27, 2003 Messages 266 I wanna buy a usb pci card, and im wondering if there's any particular brand I should get? or any particular brand I should not get. Thanksssssssssss
Oct 14, 2004 #2 S Stefan Limp Gawd Joined Apr 27, 2003 Messages 266 just one suggestion? i dont feel like spending 20 dollars on a shitty card, when someone could spend 15 seconds of their life preventing this!
Oct 14, 2004 #3 S SureLock n00b Joined Sep 19, 2004 Messages 45 IOgear makes a fine PCI usb card, when mine was installed there weren't any problems with it.
Oct 15, 2004 #4 C Chelica 2[H]4U Joined Aug 8, 2003 Messages 2,698 I have installed a few Adaptecs and they work fine.
Oct 15, 2004 #5 P potroast Limp Gawd Joined Oct 3, 2004 Messages 401 the USB chipsets are all pretty standard. There's only 3 or so, anyway... Just find a card that has a layout and # of ports that is agreeable to you. Syba is inexpensive, as an example.
