Check in the BIOS for settings for a parallel port. If you find some then the motherboard supports it. If the physical connector is missing that could be a pain. In that case there is likely a header (double row of pins) on the motherboard that you connect a ribbon cable with the connector on it to. If you don't have that dongle it could be a pain finding one. Keep looking for a driver for your USB to parallel port dongle. Have you tried using the XP driver.
That's what he's trying to use.I'm starting to suspect that he has a USB->Parallel adapter that he was using on the old computer.
whats the brand of the USB -----> parallel port adapter? tried googling for the driver for it?
iam surprised there are vista drivers for this dot matrix printer in vista.. i had a HP 3820 - 4 yr old printer that wasnt supported for Vista... ended up throwing it out (died anyways)
props to panasonic for making vista drivers for legacy printers?
