usb keyboards any better now?
iroc409
looking to replace my (roughly) 7-year-old MS natural pro (or elite?) keyboard. works great, but it's getting old, and that new crazy fancy natural has caught my eye (although it has so many buttons, not sure what i'd do with it).
i've always had trouble with usb and this keyboard, so i just stick to ps2. what's everyone's experience with usb now? reliable? it seems it's much better with the ones i use at work now, but still can occasionally be hit-and-miss, depending on the keyboard.
is it possible that my keyboard is just too old, and the keyboard technology itself has advanced so much? it gives me so many headaches i just stick to ps2. thoughts?
i'd get their cheap no-frills ps2 model, but i can't stand the tiny arrow keys and insert/delete/pgup/dn. yuck!
Dude, it's 2006, not 1999.
Yes, of course USB keyboards are reliable.
The only issue I have had is the num lock key will not stay on even though I enable it in the bios. If I use a ps2 keyboard it is not a problem. Other wise no problems.
I have a usb keyboard on my other pc and sometimes it doesn't respond so I either have to replug it in or restart. This is a shitty keyboard though.
maybe my work keyboards are just cheap... they REALLY don't like kvm's much. i guess i didn't think the keyboard ITSELF would improve much.. it's just a keyboard, right?
that makes me feel better about buying a $60 keyboard again :)
Just get a keyboard that costs more than $10 and you're OK. My current USB keyboard I bought back in 1999 and it's still going strong...
