USB Keyboard/Mouse not working
Sly
I just upgraded so i'm not too familiar with it yet. But i seem to have an odd problem.
I've been hibernating rather than doing a complete shutdown for a while now since i can just leave everything on the desktop and they'll still be there when i turn the PC back on the next day.
The problem is that the new pc disables the usb when i try turning it on from a cold start.
When i hibernate, as long as i leave the power cord plugged in, i'll be able to go back to the desktop with no problem.
When i hibernate, if i were to physically cut the power from the outlet too, the next time i boot up windows, i'll get stuck on the password screen coz the keyboard and mouse won't work. The keyboard works normally prior to Win7 since i can still access the bios, however, once windows starts up, the keyboard and mouse stops functioning. I have to hit reset to get windows working again.
might have to check the bios and make sure usb support is enabled.. even though they work in the bios it may still be causing a problem.. even my keyboard/mouse worked in my bios but usb support was by default disabled.. see if that helps..
btw in windows 7.. even when you shut your system down.. it will automatically open all the windows that were open at the time of you shutting it down.. should try it with all your usual stuff open.. shut down and turn it back on and see if it all opens again.. i know it works for me with firefox, microsoft word, and some other stuff running in the back ground.. heck even when i accidentally left a movie open in the back ground when restarting it opened the movie right where it was paused at..
