the jumper would be MALE and the regular usb would have to be female(like a regular usb cable end)
didnt see the last one..but thats what im looking for
The card reader is 10 pins because it requires two ports each USB port is 5 pins Well 4 + Shield
Is there a USB Port on the front of the card reader? If so that's why it requires two ports (One for the card reader and the other for that USB Port)
can you plug and unplug a usb header while the pc is on? or is that just bad in general for the computer
The USB Spec says it is hotplug capable. (Meaning you can plug in a device when the computer is on) But for a header I would not because if you plug it in the wrong way or miss a pin it would fry the device or motherboard or both. I always double check my USB or other headers before I turn on the computer. In other words it possible but I would say its a bad practice to do that
