May 4, 2007 #1 I isaac27 Limp Gawd Joined Feb 11, 2007 Messages 152 I Install MS Virtual PC in my PC (OS=WinXP PRO+SP2) I've try to add USB Plug n Play for new Mechine...I can Found it It Don't even Show in the Setting Menu! Is there Away to Add USB Suppurt for the mechine? thanks isaac
May 4, 2007 #2 swatbat [H]F Junkie Joined Apr 25, 2001 Messages 13,052 I was under the impression that virtual pc still didn't support usb. VMware does however. What are you trying to install? If it is a printer or something just share it off the host os.
