USB Hub on another USB Hub?
cpthk
I plan to extend the USB ports. I currently already have a 4-port USB Hub. If I buy another USB Hub and plug in on my current USB Hub, will it work? Or they have to be plug into ther motherboard directly? Has anyone tried it before?
Thanks.
Just make sure they are all powered. You'll have issues if you chain passive hubs like that.
Kinda not really. You can daisy chain powered off of a non-powered just fine. I ran such for quite a long time on my old system due to not enough ports on the back. (two printers in the closet on a 15' cord, were plugged into the unpowered hub for keyboards/mice)
you could probably chain another non-powered off of that second powered if one really wanted to though I wouldn't bet on it.
what he said...
The thing to remember is a laptop-type hard drive or a scanner that draws all it's power from USB should be plugged into the computer directly, or into a powered USB hub. you could probably daisy-chain a couple passive hubs if all the devices had external power bricks or wall warts.
It should be noted, however, that many motherboards have multiple USB Root Hubs. that would mean that theoretically, you could have 480mb/s to a hard drive on one hub and 480mb/s to a scanner on a different root hub.
as long as we're on this discussion, I remember early premium USB 2.0 hubs that stated that they could allow multiple 1.1 devices to communicate at max speed at the same time, by buffering the incoming 1.1 transmissions and passing them to the computer at full 2.0 speed, could a USB 3.0 hub do the same and allow you to saturate the 3.0 bus with several 2.0 devices all working at once?
