USB Headset & Vista x64 Help!
bigdavethehorn
Hello all, I own a Logitech Premium USB Headset 350.
On my old PC, and in Win XP, when I plug the headset into the PC, the headset takes control of the sound output and the sound only goes to the headset, as it should.
However, on my new PC, in Vista x64 SP1, when I plug the headset into the PC, the speakers remain the default sound output device.
I can select the headset as the output device by going into the Control Panel, however I would much prefer this to be an automatic function if possible.
Can anyone help?
Fixed it.
Simply set the headphones as the default device in Control Panel, then whenever they are plugged in the sound is directed to them, and when they are unplugged, the sound returns to the speakers.
