Canon said:Ok this is what is happening:
When you plug the headset in windows automatically selects the USB headset as the default Playback (and maybe recording if it has a mic) device. This has the effect of making it seem like the sound card is in fact disabled (it's probably not).
To get around this there are two things you can do:
1. If your software supports it (IE: Teamspeak, Ventrillo) manually configure the sound input/output device in the software (do this when the headset is connected so you can see both devices on the list).
2. If your software doesn't have this option:
Go to Control panel->sounds and audio devices->audio tab. Select the device you want sound (input or output) from and click OK. Now start the software you want to hear through your speakers (IE: Windows Media Player). Now repeat these steps and select the other device that you want sound from and open the software you want to hear through it.
I am taking this knowledge from experience that I have with a USB sound card.
