mr_oh_so_ice
- Dec 3, 2005
I can't figure out why when I copy files from any one of my hard disks to my 40GB Fujitsu USB HDD, some of the data gets corrupted.
All my PC hard disks are fine, I checked them and the files are fine too via CHKDSK. I have two 320 GB Seagate SATA2 disks, 1 WD 120 SATA disk, and an 80GB WD IDE disk. I checked them for bad sectors, file errors, etc, no problems, all are NTFS formatted, as is the 40GB USB disk. I always use the safely eject option for the USB disk, so there should be no problems with unwritten data, my RAM has been checked and there are no issues.
For example, I copied my large 500 MB font RAR archive over to the external. Tested the archive and immediately it was corrupted. Checked it on my hard disk, its fine. Recopying the file worked and now its fine, but then I copied some MP3s over, and 6 of them have invalid indexes and won't play. Check them on my regular hard disk.....yep they are fine.
So whats going on? I checked the external disk for bad sectors and its good, I tried plugging the drive into different USB ports, again same problem. Is it just a crap drive?
