USB hard drive locking software
camay123
I have a USB hard drive, that I wont to protect by being only accessible if you enter a passsword. Does any free software can do that ?
Thanks
zoobaby
Not sure, but you may be able to find a free encryption program. Also, I believe that you can put a password on a folder. Just use one folder, tree underneath it and put on the top level.
