USB Flash Drives
Which would you buy?
  • #1 SanDisk 256MB Cruzer Mini
    Votes: 0 0.0%
  • #2 SanDisk 26MB Cruzer Micro
    Votes: 5 100.0%
  • Total voters
    5
nerdawg4
I want one for school, several of my classes involve files larger than floppies, and we are allowed to use these, so hey, good solution.
Anyway, I figured s few of you here on the [H] would have one or know a thing or two about them.
I am deciding between these two:
It is small, and will fit in a set of 2 USB ports that are side by side (with a plug in the other port at the same time). I am not sure if it is too long to fit up in the dell optiplexs we have at school or not, I would suspect that it would fit without a problem (let us know if you know).
#2 SanDisk 256MB Cruzer Micro
This one is shorter than the Mini, and I like the blue activity light, and it is only a dollar more. I am not sure if it will fit as well as the first one (side by side with another plug) (I suspect that it too would fit without a problem) and I like the looks of it better. If any one knows anything about the relative size of this, let us know.
What would you buy?
I'm not at work so I can't compare them side by side, but if memory serves me, the Micro is a good amount smaller. It's may also have a nice aluminium cover, not plastic.
