Cost per gb is high. In fact, it's $2.50/1gb.
Same capacity as DVDs, but you can put it in a shirt pocket or hang
around your neck. Well, woopeedoo. I could get a mini external HDD
for $100/500gb and wear it around my neck like I am Mr.T.
Also, if you have a CF/SD card reader, or slots on the PC, you could use CF/SD cards instead. And SD/CF cards are used in cameras, so they are not single use like Flash Drives. I just got a 4gb SD for $9.99, but a 4gb Flash Drive is $14.99.
