Hello,
I would like to provide some extra ventilation for my laptop. Although there is probably a better option, I am thinking of building an external small fan to work with a USB port. It should be a 5 Volts, silent, small fan, which I have to look for.
Questions:
- How many amps would you say I can get from the USB port? I do not want to damage the laptop...And forget about battery - I would use the fan only when feeding the lap from the wall.
- Which of the USB wires are the 5V and the negative?
Thanks
Questions:
Thanks
