USB external drive not recognized
Erch
I'm having some troubles with an external enclosure and my sister's new imac.
The enclosure I'm using is a Tao Tec 2500 (2.5" drive) IDE --> USB device with the Y-cable. The drive has been formatted to NTFS and has some files on it. As far as I can tell though the version of OSX the new imac is running should support read capability with the file system though.
The computer is a latest generation imac (purchased about 12/20/2006) and running a new revision of OSX (about 1.0.4.7 I believe).
My problem seems to be the computer simply does not recognize the drive. Disk utility doesn't see it nor the usb manager in system tools. The LED indicator on the drive indicates that it's receiving power and I've tried swapping the usb ports around just to be sure I don't have a bumed port. It simply seems like OSX just doesn't know the drive's there.
Any help or advice in the right direction appreciated.
