usb drive wont work after unplugging it during file transfer...
Andrew_e1
Hello,
I gave this usb flash drive to a friend as a gift http://www.supertalent.com/products/stt_usb_detail.php
its the 8gb pico usb drive, ive had one for over a year and ive had no problems but my friends wont work after he told me he accidentally unplugged it during a file transfer on his mac.
If i plug it in to a mac it wont see the drive, not even the disk utility...
If it plug it in to a vista machine, it gets seen but it says "unknown device" and it wont show up under disk management either...
Is there any possible way to fix it? this is a first for me since I thought you could not damage usb drives if you unplugged them during a file transfer (except for normal data corruption).
Any ideas?
thanks
You may be able to fix the broken drive using the instructions and programs in this blog post. Be cautious, though, as it warns of possibly damaging your machine or drive if done improperly. Just follow the instructions exact and dont open or use both programs at once, as that blog indicates it may damage the computer! Otherwise, you should be able to fix the drive if it has not been permanently damaged. Most likely it was just a corruption from pulling it out too soon that can be written over using this process.
Normally that message means that Windows detected that you plugged a device in, but was unable to enumerate it, so no USB session is established. There's no avenue for communication between the device and your computer, and chances are it's completely useless now. That blog post might be worth a try, but chances are it's toast.
