i build a new computer out of some spare parts i had laying around last night, the specs are below.
my problem is that i cannot get my usb drive or external usb hard drive to work on it.
i installed windows xp pro with sp2, did all the windows updates, installed all the drivers and verified that all the usb ports do work by plugging a usb mouse into each one. the mouse works fine, but i cannot get any usb storage devices to work on it?
the specs:
intel p4 2.0ghz 400mhz fsb
jetway p4xfcp motherboard
Radeon 9500 np
512mb pc2100 ddr
30gb maxtor hd
350 watt antec truepower
the usb drive is a sandisk cruiser mini, also tried my old lexar 16mb flash drive with the same problem
when i plug either drive in it makes the new hard ware connected noise, and it shows up in "my computer", but when i try to open it it just says (the request could not be completed because of in I/O Error".
witth the hard drive nothing at all happens, it just makes the noise then the computer begins to get slower and slower until i unplug the drive.
any ideas on how i can fix this? i tried reinstalling the usb and chipset drivers with no luck
the specs:
Radeon 9500 np
512mb pc2100 ddr
30gb maxtor hd
