usb devices malfunction
levi@th@n
About an hour ago, I was at my computer doing nothing out of the ordinary; i was just playing around with adblock for firefox if u must know the details. Anyway, all of a sudden I touch the keyboard and I hear two quick soft snaps. I honestly have no idea where I heard them. I was wearing a sweat shirt that gets a lot of static very easily. Perhaps the snap sounds came from the keyboard? Not sure.​
Ten seconds later, my mouse freezes and the balloon saying that a usb device has malfunctioned comes up. I can still use the keyboard. The thing is is that my mouse and keyboard have been freezing up occasionally (not often enough to make me search for a remedy) for the past few months and in past occurrences the balloon that I just got has never appeared before. Normally I just disconnect/reconnect the mouse and keyboard and they're fine so that's what I do. Suddenly the keyboard stops working as well and now they are not working after several reconnects.​
I try a cold boot. I try turning off the psu and even unplugging it. I try different usb ports. I have 4 in the back that are onboard and 2 on top that are external. The external ones are not loose. The optical mouse lights up. They work fine with other computers so the devices are fine. I then tried a ps/2 keyboard. Nothing. Ok so now my usb ports and ps/2 ports are not functioning. I recently disabled my serial ports so how am I supposed to access anything on this computer?​
I plug the keyboard and mouse into the 2 external usb ports. The computer doesn't turn on. I turn off and turn back on the psu. The computer turns on and then dies out after 2 seconds. I try again. Yeah, it's rather dead alright. Here are some specs to help anyone out:​
os: winxp sp2
case: thermaltake tsunami dream (tsunamis are certainly not "dreamy")
monitor: nec-mitsubishi FE991SB-BK 19" crt
mobo: ga-k8nsnxp-939 F6
cpu: a64 fx53-939 w/ stock heatsink (soon to be thermalright xp-120)
gpu: nvidia geforce 6800 gt w/ arctic cooling nv silencer 5
ram: 2x512 corsair xms xtra-low latency (2225) ddr400
hd: 2 74gb wd raptors
sound: audigy 2 zs card, logitech z-2200 speakers
psu: thermaltake purepower 560w (insuff. power shouldn't be a problem here)
floppy: 1 generic
dvd: 1 px-712 internal atapi dvd/cd rw, 1 asus e616p1 internal atapi dvd/cd rom
fans: 2 120mm, 1 92mm
I believe that's it. Any help would be appreciated.
hey, just wondering if you found the solution to your problem??? the same thing just happened to me. My mouse stopped working all the sudden and i reached up and shocked my exos watercooler, and my PC locked up, now my computer will just turn on for 3-4 sec and then shut off :(
I think i have my problem somewhat narrowed down..... I finally got the computer to stay on after i took out the CPU.... so either my cpu is fried, the MB, or both :( :(
