[U]ber|Noob
- Apr 4, 2013
I am having a problem with my mini pc.
When you start the computer, every so often at least one usb device fails to work (the device is powered but the computer fails to detect the device).
It is fixed by either restarting the computer or unplugging the device that didn't come on and plugging it in again.
This has become a very annoying problem. I have a powered usb hub connected (just a fairly cheap ebay one) but this issue also effects devices connected directly to the computer's usb ports not going through the hub at all.
It is common when you turn on the computer that there is no sound (due to usb sound device not connecting), another time there will be sound but the usb remote control won't work. A lot of times everything works, but then it doesn't the next day when nothing has changed.
The motherboard is
Intel dh67cf
With Windows 8.1 (with latest updates).
This has been on ongoing problem for ages.
Any suggestions about what I can try to fix this would be greatly appreciated.
Should I replace the hub (even though it effects devices not connected to the hub)? or something else? Could one device cause problems with all the other devices?
It wasn't a cheap mini pc (about $500).
The motherboard is
Intel dh67cf
