USB Card computer won't boot
Quak3R
Hi,
The title pretty much explains it. I have a rosewill 5 port usb card installed. I reset cmos and i booted up now the computer boots alright but then it stops at boot screen and just posts what cpu im running, and nothing else (ram, hard drive, cd-rom won't post) now i remember having a similar problem with booting up while having my flash drive installed, but when i remove it, it will continue to boot. But i kinda need to install this, and the rosewill manual says nothing about this problem, anyone have any ideas?
system i am running in this computer:
Asus A7N8X deluxe motherboard
512mb kingston pc3200 ram
Sapphire 9800 non-pro
Samsung 52x cd burner
Seagate ATA/100 120GB hard drive
Aspire 500 watt psu
A couple things to try:
In bios disable "Boot Other Devices"
Disable "Boot to USB"
lmao, cooter, you made me look like a total noob, it works now thanks.
