USB Add-on board
Oscar
Hi!
I have an NEC-Chipset based usb add-on card. (480 Mbps Hi-speed USB 2.0):eek:
In its ports (4+1 internal) i plug an mp3 player. usb pen drive and other cool stuffs!:cool:
I had plug a mobile-phone (Samsung) but its software don't work correctly.
The connection hang out after few seconds... i cannot transfer media from/to pc or sms...:mad:
If i plug this mobile device into mobo-embedded port... it runs fine!;)
Why?
PS: I can leave this config 'cause the device is not usb 2.0 compatible....
Something tells me that your phone may be the problem. Assuming that you don't have any problems with the other devices that you plug into your USB card, it's either because you have a bad connection cable or that the phone/software/service isn't allowing you to access your phone's content. (And FYI, USB 2.0 is backwards compatible with USB 1.1 devices... but I thought that most phones today use USB 2.0 to connect directly to the computer....)
But you only told us half the story... what phone do you have (the full model, not just the fact that you use a Samsung)? What service/plan do you use? What software are you using with the phone?
Hi!
I use a Samsung SGH-E330 with EasyStudio Software!
Sometimes this software (in the card port) inform me that the SIM of my phone is not inizialized!
I had try to off/on the phone or extracting for a few minutes the module but don't work... ever!:mad:
The Blueray:cool:
