I have built myself an HTPC using the Wesena ITX-7 case (with USB2 front port). Ive got the Asus F1A75-I mini-ITX motherboard that has a USB2 header and USB3 20 pin header.
My problem is that Ive used the USB2 header for the inbuilt IR receiver and the memory card reader. I need to connect the two USB 2 headers to the motherboard so have been looking at a USB3 to USB2 adapter solution.
Is there any solution to this? I bought this: http://www.coolermaster.nl/shop/popup_image.php?pID=807&osCsid=ujbbif6q7l59dlu4qk14jjd9c7 but the usb 3 end is the male type. I need a female end to connect to my board.
The USB 3 header on my motherboard is circled in red in the following picture:
http://imageshack.us/photo/my-images/805/motherboard.jpg/
