usb 3.1 slot
ralphie1313
Hi i dropped coffee on the front of my rig were the 2 usb ports are and now they do not work, i am wondering do you guys think
i blew out that dual cable that connects into the 20 pin usb 3.1 connector, or do you think i blew out the 20 pin connector. I just wanted to see what u think
before i order a wire just to try... Thanks
Oh P.S. if the problem is the connector 20 pin on the board can it be fix? or i need a new board and its a x399-e rog
