Usb 3.0 mod
Hotthree
Anyway to put http://silverstonetek.com/product.php?pid=311&area=en
in a Raven rv02-ew?
I bought it but did not realize no extension came with the mobo. Is there ways I can get a male 20/19 pin connector or does anyone have a mod they have used before?
I may just be out of luck on this buy. I can always use on my next case/build.
I am willing to ghetto mod to a certain degree..I know I will if I attach it on the front panel.
Thanks,
What exactly are you trying to do?
That item listed is for connecting USB 3.0 plugs to a USB 3.0 motherboard header, as the early front panels connected that way.
If you need to connect a plug to the motherboard and need more length, why not just use a USB 3.0 extension cable?
Thanks for the recommendation, I was lost on exactly how I was suppose to use that cable ha.
