USB 3.0 HEADER SPLITTER?
Auburn_Tigers
I have 4 usb 3.0 ports up front, but only one motherboard header.
Has anyone tried the y splitter they make for the board header, and
if so, did it work? I have a pci card that I could use, but I would much
rather get the 3.0 ports working without having to use it.
You can't really "split" USB in the same sense as a fan splitter where it's just wiring. A USB Y splitter cable can drive one port or the other at any given time, but not both. You either need an add-in USB card, or some sort of internal USB hub.
What case you rocking?
Cooler Master c700m. They also have the c700p black​
edition also, but that thing is ugly as crap to me.​
I've never tried the usb 3.0 splitter. If they made a hub it could work but dividing the signal, I don't know.
if you have a USB 3.1 port you can get an adapter to change it out to the 30 pin usb 3.0 port, a lot of people don't recognize this port so maybe you'll get lucky?
https://www.amazon.com/Cablecc-Front-Header-Extension-Motherboard/dp/B078BQVM2X
if not, you can also relegate two of those four ports to USB 2.0 speeds ala https://www.amazon.com/Cablecc-Reversible-Housing-Motherboard-Adapter/dp/B0816C3ZV6
I did this using that same exact cable and it worked perfectly. This also has the added benefit of allowing you to use ALL 4 ports at once, not just one set or the other....
OTOH, if your mobo has USB 2 connector, you could use that too, albeit with slightly lower performance...
or as you stated, use a pcie card to get the other 2 ports connected & working at USB 3 speeds...
