Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I need a USB 3.0 Hard Drive Dock with a few USB3.0 ports on the front (USB 3.0 Hub). Have you guys found any? A search on newegg doesn't pull back any with the hub part.
AFAIK you won't be able to find any like that, the problem being that USB 3.0 is designed for faster transfer rates, so for a HD dock they would want the entire pipeline for data transfer to/from the dock, not for a hub. Your best bet would probably to buy a USB 3 HD Dock, hook that up to a dedicated powered USB 3.0 Hub, and then to your computer.
