anyone got one of these? I'm trying to find out if a USB2 external enclosure that houses SATA drives would be as fast as having the drives internal to the machine. I'd like to put together a USB2 external raid enclosure but speed is concerning me.
yes, a good Firewire (even 400) enclosure is likely to outperfom the equivalent USB implementation.sdadept said:that's a good point, I hadn't thought of that. Most of the motherboards I've bought recently have firewire ports so that might be the right way to go.
so the usb2 speed just doesn't cut it for sustained throughput then?
Also noteworthy is http://en.wikipedia.org/wiki/Usb#Technical_detailsdavidlem said:Exactly. For further reference, also see http://en.wikipedia.org/wiki/Usb#USB_2.0_Hi-Speed_vs_FireWire
note paragraph three
