Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Using a usb2 external enclosure for one of my sata drives. Is it possible to buy something cheap that would be like a usb to firewire adapter? If so, is it a good speed increase? Thanks.
Firewire tends to be faster because the controller itself offloads and directly manages much of the communication.
Honestly, unless you're planning on regularly transporting/moving/copying 10GB+ a week, you're probably not going to gain any real world 'benefit' from using the drive.
