USB 2.0
not1germ
I got my system together, but when I plug some usb devices into the USB port, it some times says that it would be faster if pluged into a 2.0 USB port.
My mobo is supposed to have USB 2.0, so what could be my problem?
Have you installed your chipset driver? That usually comes with USB 2.0 drivers too.
I would check the BIOS settings.. On some mobo's there are options to set the speed of the USB.. 1.1.. 2.0.. etc.. Some mobo's list it as Hi or Full Speed..
Hope this helps..
what OS are you running? USB2.0 drivers are part of windows xp SP1/SP2.
Funny. I have the same issue with a PC I put together w/ some older parts.:
MSI PM8PM-V motherboard
P4 2.53
gig of Corsair
9500 Pro
Running Win XP SP2
The rear ports run at USB 2.0, but anything I plug into the MB USB headers only runs at USB 1.0. I'm certain at least one of the hubs I plugged into the header(s) is USB 2.0 compatible because I've used it before on another build. Just to check, I contacted MSI tech support and they said ALL USB's on the board are 2.0. Very strange. I've double and triple checked all the setting in the BIOS. Reset the BIOS just in case. Re-connected the USB cables. I'm stumped.
uninstall the usb root controller in device manager and reboot. windows should re-detect it and re-install the drivers for it.
