Hello, I built a computer for a customer and am having trouble getting the usb 2.0 to work. It is an IS7-E running Windows XP home edition. On the cd that comes with the motherboard it says then when you go ton install usb 2.0 drivers
USB 2.0 Driver Installation Guide
Windows XP
1. Make sure your system can connect to Internet.
2. Link to Microsoft Windows XP SP1 download page.
3. Click "Network Installation" in Installing SP1 on Multiple Computers column. (You can choice "Express Installation" in Installing SP1 on Your Computer column, if you don't want to download full SP1 file.)
4. Select your language and click "Go" button.
5. Click "SP1 Network Installation (32-Bit)" to start download Windows XP SP1.
6. After download finished, execute the SP1 file to update your Windows.
7. After Windows update finish, click "Start"->"Control Panel".
8. Double click "System".
9. Select "Hardware" tab and click "Device Manager".
10. Right click on "Universal Serial Bus (USB) Controller" and click "Update Driver...".
11. Click "Next" and system will search and install USB 2.0 driver automatically.
I have sp1 installed, but when I follow the above instructions it just says it cannot find a better match for the hardware. Any insight?
Windows XP
