pbXassassinX1524
- Nov 24, 2003
Hi everyone, I'm having a problem with my PC and as far as I can tell it has something to do with the USB 2.0 functionality, it started when I moved into my appt for college and I kind of fear something happened in transport. (although there is no visible damage to anything) Anyway, here are the symptoms I'm experience with my sole USB 2.0 device, an SIIG AV Tuner Pro-PVR; which I tested on my room mate's PC and it worked perfectly fine.
Normally I can install it without a hitch, just load in the drivers, restart, plug it in and it will install fine. However, sometimes I get this error saying that it has malfunctioned and can't be installed (which I know not to be true), other times (and sometimes simultaneously) I get "this device could be running faster" talking about how for some reason its been degraded to USB 1.1.
When it does install properly, shortly after using it (always <1 hour) it will either completely lock up (the box itself, and WinDVR) or windows will make a bunch of "unplugged" noises and I will get that "It could be running faster" bubble. And of course there are some other strange anomolies that have happened too but each one only once.
I have tried 4 different USB ports to no avail, I though it was a software problem so I reinstalled windows, that didn't work either. So now I'm hoping that some of the brilliant people out there can shed some light on the situation for me.
PC specs are in my sig, if necesary.
Thanks a lot to anyone who can help!
