May 17, 2012 #1 T tonyyy Limp Gawd Joined Nov 10, 2009 Messages 306 Looking for a cheap solution for usb over ethernet. Has to be 2.0 compliant. So far I found products online ranging from 100 bucks or more Is there some easy and low cost way to do this? I already have the ethernet wired at both sides.
May 19, 2012 #2 E EvilAlchemist 2[H]4U Joined Jan 11, 2008 Messages 2,730 USB 1.0 & 1.1 over CAT 5/5e/6 is very cheap. =http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10303&cs_id=1030313&p_id=6042&seq=1&format=2 USB 2.0 over CAT 5/5e/6 is still expensive. What device are you trying to send over the network wiring? There may be a better solution if we had some more details ... ??
May 24, 2012 #3 T tonyyy Limp Gawd Joined Nov 10, 2009 Messages 306 I ended up ordering an active usb extension cable from monoprice. i got a 65' cable and it is able to power the webcam fine compared to the usb 1.0 over ethernet. i will be running this through the attic and wall this weekend to hide the cable
