USB 2.0 hub output power
Chris
I have a Zen Micro Photo which charges through USB port in my computer.
It doesn't come with a wall charger which is supposed to charge my ZMP faster than using my computer's USB port. This wall charger from Creative has the following specs:
100-240VAC~50-60Hz.0.3A
Output:
5V - 1000mA
If I use this wall charger, does it mean that the USB port in my ZMP will receive 1000mA during charging? Wouldn't this mean it is out of USB 2.0 spec which is only 500mA max ?
Secondly,
Does a self-powered USB 2.0 hub give out 500mA to each port guaranteed ?
Can it do higher, say 1000mA just like the original wall charger?
Am I correct to assume that a 4-port USB 2.0 hub should have an adapter of min. 2000mA output to guarantee 500mA for each port ?
I ask because I have seen a 4-port USB 2.0 hub with adapter rating only 1000mA. (????)
I'm considering the pro & cons of buying the original wall adapter vs. USB 2.0 hub to charge my ZMP. If the original wall adapter is really capable of supplying 1000mA thru USB port, then I assume it will charge much faster and is worth the price. OTH, if the wall adapter is still supplying a max 500mA (as specified by USB 2.0 spec), then I assume it couldn't be any better than a simple USB 2.0 hub, which is much cheaper, and they should charge equally faster.
