Hey Guys,
I just upgrading my computer to a Conroe 6400 cooled with a Zalman CNPS7700-CU, Giga p965-ds3, and 2gb gskill ddr2 800. I applied the AS5, but it seemed thicker and harder to spread than I remember(it's been a long time since I've needed to apply AS5, about a year and a half.) Is there a certain point where you should order new AS5 instead of using old stuff?
I ask because I overclocked my 6400 to 3.0 gHz(400 FSB was giving me problems, but I didn't have time to play around with it or update the BIOS) at 1.3375v in Bios, less in CPU-Z of course. Anyway, temps seemed to idle at the low 40s and under load with TAT or orthos temps(according to TAT) were about 52 or 53 after 5-10 mins. Speedfan reported the CPU at 30.
I know the temps will drop a bit after the "break in", but they still seem a tad high.
1. Is it possible I should've ordered and used new AS5?
2. Why are speedfan's numbers so different?
3. Do the temps seem in range given voltage/overclock/cooler? The room is probably about 68-72F.
